can anyone here tell me how to duplicate the animated flames on this piece of footage?[1]
(i.e. required software, etc)
Thank You.
[1] http://rapidshare.de/files/12129337/BK.mpg.html
Results 1 to 13 of 13
#1 Stunna
Believe you can do it in most of the mid-hi range 3d software, though they probably just bought the rights to the clip. That said, might have some fun with Quicktime's MakeEffectMovie.exe from back in '99 if you can find it.
That one looks like it was done with mostly 2D software. Simplest way is to go to somewhere like ArtBeats Reel Fire series ( http://www.artbeats.com/prod/product.php?pg=1&id=214 , http://www.artbeats.com/prod/product.php?pg=1&id=352 ) and some fancy masking
Read my blog here.
hmm... thanks guys.
I'm new to video editing, but I am learning very quickly.
having the proper tools is basically 90% of the job, so thanks again.
-$tunna#1 Stunna -
After Effects would be the easiest to do this, however if you are just starting out, look at Wax2
Read my blog here.
Yes sir, I own After Effects. It's just so complex like most Adobe products.
However, that usually means that it's good.
So, I had to order a training CD from Lynda.com.
I hope it helps. I have read a lot about both Wax & After Effects.
BTW, that Reel Fire stuff you posted looks almost exactly like what is in that commercial. Maybe they used that also... small world...
Thanks for all your advice sir. Maybe you can answer my other question from last year?[1] I found that this can be done w/ almost any video editor, but maybe you can recommend a better one, a colleague has already recommended Sony Vegas:
[1] [?] How To: Slow Video Speed & Repeat Frames?
Thanks for everything.#1 Stunna -
Thanks everyone for your help, I will give these methods & tools a try & I will post my finished work here.
Thanks.#1 Stunna -
S1inger, any tips on how to do this in After Effects? This sounds interesting to me, but I don't have trueSpace.
I'd like to create an effect where a logo/image in the center of the screen explodes, and it would be cool to have some fire & particle effects behind this. I'm actually having trouble getting my still image to break into particles as well, but I'm sure if I keep digging around here on this site I'll find the answers to this little problem (always do...)
I have Premiere Pro 1.5, After Effects and just got Wax (although haven't used it as yet...)
Stunna, how did your effort go? Gonna post it up for all to see?
Thanks guys... -
Originally Posted by Raniburger
after using ParticleIllusion I would recommend using custom tools / plugins to create effects like this vs doing it from scratch.
-$tunna#1 Stunna
Req. .rv to .wmv converter or .rv player
By naufil in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2009, 04:20 -
Req: Software For A Faster Pc Start
By Teac23 in forum ComputerReplies: 8Last Post: 14th Jan 2009, 09:46 -
Filter anti "flickering flame" effect?
By park84 in forum RestorationReplies: 1Last Post: 6th Jan 2009, 10:02 -
Zoom into an animated mask // After-Effect
By kiwikiwi in forum EditingReplies: 2Last Post: 8th Dec 2008, 12:53 -
REQ : - SOUND Distorted from footage
By mojoeuk in forum EditingReplies: 2Last Post: 23rd Nov 2007, 14:54
